Wanted. Blizzard swing arm bushes
Hi does anybody know where i can get swing arm bushes to suit a maico blizzard? Are m250b ones the same?
Re: Wanted. Blizzard swing arm bushes
The bushes No. 2429 can not be bought. The M 250 B does not have the sparepart.
I think the last time I made bronze bushes .
1825 is the number i have on my book
hello Matt,Mattoblizzard hat geschrieben:1825 is the number i have on my book
No. 1825 are the steel/rubber bushings from the rear wheel swing.
The bushings are the same part as M 250 B Modell, the part No. is 4770.
You can get in Germany perhaps 20€ per piece.
Regards Günter
Would you know where from? Im located in australia
hello Matt, I have at the time also no more, would order 2 pieces for you, I can send you by registered letter to Australia.Mattoblizzard hat geschrieben:Would you know where from? Im located in australia
Regards Günter
I didnt realise you replied. I have messaged you
I will order two sets tomorrow. If I have received it, I will notify you.Mattoblizzard hat geschrieben:I didnt realise you replied. I have messaged you
Regards Günter
